Been having a small problem with some burns recently.
2/3rd the way though some films I'm getting small artefacts
which after a further few minutes the whole picture breaks up
Been using DVD Decrypter / DVD2ONE
Nero 5.5.10.7
Sony DRU500AX
1 GB Ram
2.66 P4
Bulkpaq medium (1x)
Tried using DVDXCOPY that’s ok but HATE the idea of using 2 disks.
Tried IC7 but the registry hack wont work on the fully paid version (did on the trial ver) so I can’t remove the video stuff you don’t need, therefore quality is shite.
BTW has anybody been able to get the reg hack to work with IC7 ??
cos if you have please tell. IC7 would be my preferred encoder.
Regards Mark
Results 1 to 1 of 1
Artefacts when streaming a high frequency signal through S-VHS
By mamoltub in forum Video Streaming DownloadingReplies: 5Last Post: 24th Apr 2012, 10:46 -
Is it possible to Fix Bad Reception Artefacts with AviSynth??
By VideoFanatic in forum RestorationReplies: 6Last Post: 15th Nov 2011, 16:31 -
Need help removing some artefacts
By kotyczka in forum RestorationReplies: 28Last Post: 3rd Jun 2011, 13:17 -
Artefacts in recoverd MPG files from JVC DR-MH30
By PGottfried in forum ComputerReplies: 3Last Post: 31st Jan 2010, 22:10 -
Capturing from my DV camcorder: artefacts with straight lines (fuzzy)
By hydrocynus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th May 2007, 20:56
