Hi,
I just set up my pc to record tv shows...i'm using virtualdub to capture and am using the Huffyuv codec to capture.
The problem I am having is getting decent quality. What I would like is to have the vcd quality to look like the captured AVI? Is this possible? How?
What settings do I use in TMPGENC?
What's the best way to achieve the best quality when converting from a tv captured video?
All help is welcomed and appreciated
Thanks in advance
dangel234
VCD is limited, so don't expect exactly the same you see on TV.
It is okey for typical movies, some anime and typical tv series.
It is not enough for music videos, scifi movies/tv series and athletic material.
There are some advance VCD encoding methods, which may make the results better, but don't expect miracles!
Do a forum search, there are plenty posts about the subject. -
As "SatStorm" stated VCD quality is limited.
I have a good quality cable TV signal going into my primary capture/encoding system. When I encode to VCD resolution there is a noticable quality difference between the VCD and what I see coming into the TV in my apartment. When I capture/encode at CVD (352 x 480) resolution it is hard to tell a quality difference between the CVD and the original signal that came strait into the TV. -
Because TV capture will be interlaced and VCD is MPEG-1 and MPEG-1 doesn't support interlace, I would suggest using MPEG-2 and SVCD format.
Tmpgenc can produce very good results there. I would pay a visit to the www.kvcd.net and check the Tmpgenc templates for high compression low file size SVCD templates. Although they don't do what they claim (at least if quality is a concern), they significantly enhance the quality to the point where you can fit well over an hour on a SVCD (at VBR ~ 2000kbps).The more I learn, the more I come to realize how little it is I know. -
I think we do what we claimOriginally Posted by SaSi
KVCDx3 "Full Screen" sample (528x480): http://www.kvcd.net/test-sea.mpg ( Use WinDVD or PowerDVD to view )
That's the way the movie looks on ONE CD 8)
Enjoy,
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Help Required. Capturing DV to PC
By jeffbhoy in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2007, 19:37 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
