I have a video file that's encoded to xvid then i converted it to huffyuv and then used vegas 4 to convert to mpeg2 using mainconcept encoder. and the audio is the original dvd 5.1 ac3 file and i muxed them with bbmpg with dvd radio check on. but when i import to dvd architect it has an error when i prepare the dvd. and spruce up doesn't accept the mpg at all. dvd workshop crash when i try to burn. what should i do? i could use ifo edit but i want to add a menu to it. thanks
Results 1 to 1 of 1
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35
