I have a bunch of short AVIs I'm trying to take to MPEG2 (DVD). I encoded each one seperately using the lastest version of tmpgenc. They are not all the same fps so I figured encoding each seperately and joining them would be the way to go. Apparently not! I can't figure out why either. I was using tmpgenc to join the generated MPEG2s. The audio and video stream lengths are not the same length! Is this as issue with my source AVI files perhaps? I was checking them over in vdub and some do not have the same number of audio and video frames. Perhaps when they are encoded to MPEG2 that extra bit of audio stream just keeps getting added to result in major sync problems?! I'm wondering what I can do to fix this. Maybe I should make all of the AVIs 29.970fps and reprocess the audio streams of each one to ensure that they all are the same length, then write up an AVISynth script to add all the AVIs into one big AVS file, then feed tmpgenc that? I'm baffled! If anyone has an idea please let me know! Thanks!!!
Results 1 to 1 of 1
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 21:18 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Corrupt .mts file problem - length too short
By nlmts in forum Video ConversionReplies: 0Last Post: 2nd Aug 2010, 17:16 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 14:55 -
Audio Out of Sync/Too Short for AVI Video
By nmycon in forum AudioReplies: 2Last Post: 4th Jul 2007, 21:00
