Does anyone know whats best, NTSF or FAT32 when converting large video's , or is there any differance to speed / quality etc ...
Results 1 to 12 of 12
if i remember correctly there wont be a difference speed/quality wise but NTFS is much better at reducing cluster slack with large harddrives
IMHO, I think that NTFS performs better than FAT32. Another thing to consider if you are working with *very* large videos is that FAT32 has a 4GB file limit, while NTFS does not.
- digvid -
NTFS uses only 64K clusters, which is actually the most inefficient cluster size. Like mentioned though, it does avoid the 4GB filesize limit (but not the 2GB AVI limit).
64K?? Sure...
NTFS uses 4K clusters IF it is windows 2000, dont know why you would be using NT4 for video stuff.... I did not know FAT32 had a 4GB file size limit, well you learn something new every day! -
Quote:
__________________________________________________ _________
What exactly do we mean by the 2GB AVI limit? I have been capturing to an NTFS drive using virtualdub/iuVCR to compressed (huffy/picvideo) avi files with file size much greater than 2GB: 6 to 7 GB for 1 hour long movies or 14 to 15 GB for 2 hour long ones. And have been successful processing them to VCD compliant mpeg files in TMP. I am using win2k.
Am I doing something right? or wrong? is there sometrhing I have to watch out for? if so what? would appreciate some commnents/suggestions
btw,
* I do not use multisegment feature of virtualdub and I also turn off the parameters under stop conditions relating to file size
Or in the case of iuVCR:
* I set iuVCR to No File Limit
Technically the AVI 2.0 spec doesn't support files larger than 2 GB. So some software may not accept them. If you aren't having any problems though, then I guess you don't need to worry about it.
Kin....thanks. Guess you're right but will keep that (2GB limit) in mind - just in case I encounter some sort of trouble with these huge files.
e.g., Adobe Premiere 5.x does not like AVI files > 2 Gb.
Regards.
Michael Tam
w: Morsels of Evidence -
here is a question if you use one format say ntfs with win 2000 and i have another pc with fat 32 are they compatible to exchange data over a lan
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
That's like asking can your MAC exchange data with my PC over the Internet. As long as your OS can read the data from the local drive(s), then of course!
The only catch is that Win 9X can't read a file larger than 4GB, so if you have a 5GB file on NTFS, then WinME won't load it.
<font size=-1>[ This Message was edited by: HillJack on 2001-09-14 01:07:31 ]</font>
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 17:59 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 14:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 17:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 10:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 12:17
