Hi there.. I've recently captured a 75 minute movie from LD to an mp2 file, using my ATI AIW Radeon 7500 at DVD-quality settings - 8mbps.. The resulting file was like 8gb which was way too big (this is gonna go on a dvdr). So I ran it through TMPGEnc, making sure everything stayed dvd compliant (the audio, etc.) and set the bitrate of the new file to be 3500.. The resulting file has sporadic artifacts.. The filesize was perfect though.. Just a little over 2 gb. Is there some way to do this with a filter or something that will avoid any artifacts? I should mention that they don't exist on the source file. Please advise.. I've been working on this dvd's menus/buttons/etc. for quite a while and have made them look professional.. The last thing in the world I need is a flawed video to lay under them. Thanks!
Butch
Originally Posted by ButchNapkins
By capturing directly to mpeg2 the first time, you lose video information. The avi/huffy combo would be a lossless capture.
I assume you want a 720x480 resolution capture but this may not be possible with avi/huffy. Depends on the speed of your system. But 352x480 is also dvd compatible and looks good.
wway -
Hmm.. I can see how that would probably work, but I'd need to take EVERYTHING off my hd to allow room for an avi of that size.. Let me ask this: Think my chances are better for avoiding artifacts if I recaptured from the LD directly to a 3500 bitrate file? Like I said, the initial capture was much bigger (and at a higher bitrate) but there were no artifacts whatsoever.. I'm wondering if TEMPGEnc is to blame here I guess.. It's done well for me many times, but this is the first time I've had to resize a big mp2 to a smaller one.. What do you think? Oh and thanks for responding!
Butch -
The problem is that a mpeg file is already compressed. When you run it thru TMPEGEnc, it gets compressed again. You dont want to do this if you can avoid it. But you did use a high bitrate from the LD to mpegs, so it should look pretty good. Not sure.
Try my first suggestion (avi/huffy) with just 2 to 3 minutes of video. See how it looks.
wway
Xvid creates blocky artifacts! Help!
By david.dgc in forum Newbie / General discussionsReplies: 35Last Post: 18th Apr 2012, 12:27 -
Encoding problem. Creates large unopenable file.
By Haole Dave in forum ffmpegX general discussionReplies: 0Last Post: 23rd Jan 2012, 16:30 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39 -
Belight creates blank file?
By snadge in forum Newbie / General discussionsReplies: 36Last Post: 17th Jan 2008, 13:40
