I followed the instructions in this guide explictily. When I'm converting the WAV to AC3 the Transcoding DOS window says (and it states this halfway through the encoding process but does not stop the process) Fatal Error MAXFRAMESIZE. And then after multiplexing it in TMPEGENC I play it in the PS2, works fine, play it on the PC with PowerDVD, works fine. Play it on my Toshiba Progressive Scan, the audio and video freeze and skip. Can anyone help?
Results 1 to 1 of 1
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 15:44 -
besweet wont reognise wav
By thecrock in forum AudioReplies: 3Last Post: 29th Dec 2007, 09:04
