I'm trying to extract a mpg file from a BIN/CUE file. I have read the user guide on how to extract it with ISOBUSTER. When the dat file is extracted it does not convert to a complaint mpg file. After extracting it, I tried to burn it in Easy CD Creator 5 Platinum, but I get a message saying it will not work in a VCD player. Can someone help me with this or tell me another way I can extract a mpg file from a BIN/CUE?
You could try using vcdxrip to extract the files. vcdxrip is part of vcdimager, and vcdeasy includes a front-end to using it.
If you isobuster gave you a .dat file, it really isn't a proper MPEG file because it includes extra headers. If it's not damaged you can make it in to a proper MPEG by either demultiplexing and remultiplexing it with tmpgenc or running the .dat through cdxa2mpeg (also part of vcdimager, and also usable through vcdeasy). -
You can just burn the bin/cue with nero as a image file and you will have the vcd you want with out any of the extra work.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
