what would be the best approach to keeping a short clip of a movie without having to re-encode the video and keeping the ac3 audio stream that goes with it? anyone have any good ideas? - thanks
True Story
put the vob which contains the clip you want into dvd2avi and use the [ key to mark the begining and the ] key to mark the ending of the clip and save project.
in the information file you will find 2 numbers (with letters) at the side of LOCATION, this is the start and end of your clip.
these numbers are HEX, so open your windows calc in scientific mode and tick HEX and type in your start number then press DEC, write down that number then do the same for the second number.
open vstrip (freeware) and load your vob, where it says start lba and end lba type you start and end numbers(the ones you last wrote down) then go to the output tab and give it a name and location you want it saving and press run.
you will have the perfect clip of that vob.
thingimijig. -
thanks a lot....ive noticed that you know a lot and give a lot of good help.....quick question will this produce a vob of the section, or an m2v & ac3 file, and if it does produce a small vob, what is the best method (or program) for demuxing it? thank a lot!
True Story -
i figured everything out.....i used the ac3 from dvd2avi and i demux the vob after vstrip with vobrator, but after vstrip, the last few seconds dont work of my video......did i **** something up with the numbers.....they are weird: let me know if you get the same numbers, thanks
DVD2AVIProjectFile
1
34 C:\DVD_VIDEO\VIDEO_TS\VTS_02_1.VOB
Stream_Type=1,0,0
iDCT_Algorithm=2
YUVRGB_Scale=1
Luminance=128,0
Picture_Size=0,0,0,0,0,0
Field_Operation=0
Frame_Rate=29970
Location=0,4FA1,0,567F
7 0 4FA1 2 3 0 1 2 3 0 1 2 3 0 1
7 0 505B 2 3 0 1 2 3 0 1 2 3 0 1
7 0 512E 2 3 0 1 2 3 0 1 2 3 0 1
7 0 5213 2 3 0 1 2 3 0 1 2 3 0 1
7 0 52B0 2 3 0 1 2 3 0 1 2 3 0 1
7 0 5332 2 3 0 1 2 3 0 1 2 3 0 1
7 0 53B4 2 3 0 1 2 3 0 1 2 3 0 1
7 0 5452 2 3 0 1 2 3 0 1 2 3 0 1
7 0 54E5 2 3 0 1 2 3 0 1 2 3 0 1
7 0 5576 2 3 0 1 2 3 0 1 2 3 0 1
7 0 5610 2 3 0 1 2 3 0 1 2 9
FINISHED
these are the numbers i got:
20385
22143True Story -
i just tried tried it with a couple diff clips, and what happens is that the last second of time is completely empty.....so say if it was a 6 sec clip at 5 sec it jumps straight to 6......do you know why - thanks!
True Story -
no idea why it misses like that, the only thing different i have done before is i got the m2v file by using vobedit.
you can also use vobedit to demux the audio aswell so it might be worth having a go to get the video and audio demuxed through vobedit.
btw, the numbers where correct.
thingimijig.
Upgrading my system: Best approach?
By lamerc in forum ComputerReplies: 20Last Post: 17th May 2011, 04:52 -
2000 DV's Capturing Per Year - Best Approach Help
By ilw in forum Capturing and VCRReplies: 2Last Post: 29th Dec 2010, 13:13 -
Mp4 demuxing: Graphedit Approach
By Krelmaneck in forum Video ConversionReplies: 6Last Post: 28th Aug 2010, 03:44 -
Best Quality approach for xfer of home video
By ironman. in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2010, 11:45 -
vhs avi to dvd, what is the best approach
By bati in forum Video ConversionReplies: 6Last Post: 11th Nov 2007, 22:37
