I am backing up a tv series that I want to fit in a 7 disk alpha case. The only way I can do it without losing quality is split each disk. If I split I will end up with 14 disks per a season. I am willing to pay more for the double sided vs 2 singles. However, I don't want to guess which episoded are on each side. Is there any way to write on one of the sides inner circles with a small number 1 or something like that?
Neato sells DVD labels ( product code 856660) which includes two "core labels" which can then be printed with their MediaFace2 label program.
www.fellowes.com
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 20:50 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 21:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 10:40
