  1. I have seen the files encoded in ASF format do takes up less space ... my first question is that ... how can we see the properties of an ASF file (means that ... at what rate it was encoded and bit rate etc etc)
    2nd question is that ... can we convert AVI/DAT formats into ASF format? if so can someone tell me the software used for it ... it would be wonderful or any link suggesting how ASF encoding is done ... since I am totally new to this ...
    thanx
    Mar 2002
    United States of America
    You could use VirtualDub 1.3c to show the properties of an ASF file.
    Here's a link to where you can download VirtualDub 1.3c:
    http://perso.wanadoo.fr/nomad/virtualdub13c.zip
    Hope That Helps!!! :P
  3. ok thanx ... yes I have that : that was the answer to my first question and what about 2nd question? the one about how to make an ASF Format file ... anyone?
    Mar 2002
    I've found the answer to your second question:
    https://www.videohelp.com/toasf/index.htm
    ASF files are low quality.
