Has anyone been able to get a Studio DC10+ (from Pinnacle) to run under windows XP (Pro, if it makes a difference)?
I always heard that it was 98 only, and I still have that, but I was just wondering if anybody has ever gotten one to work under XP.
"I think I know exactly what I mean, when I say it's a Shpadoinkle day!"
Have not tried XP { hate the mess thay did to W2k } but which verson of Studio are you running? You need at least Studio 8. The older driver from 1.06 and I think 7 wont work. They are only 98/ME grade and wont work under W2k/XP IO wall.
Also if you have 8 remember to "INSTALL" the drivers found on the install CD or nothing will work.
Studio 1.06 is only for Win 9X.
Studio 7/8 will run in XP and Win 9X.
I use Studio 7. -
cool! so I'll look for studio version 1.07 or 1.08 and it should work with a DC10+ card that originally came with 1.05. Is this correct?
"I think I know exactly what I mean, when I say it's a Shpadoinkle day!" -
Sorry you need Studio 8 or 7. There are no 1.08 or 1.07 versions. That vintage of Studio 1.x went up to 1.06 only.
After 1.06 they developed what be came Studio 7 that would run the bulk of there entry-home video stuff. Forogt the difference between 7 and 8 right now.
Current verison is Studio 8. Not sure if you can even buy Studio 7 now but Studio 8 is being sold by itself or with the same DC10+ or DV firewire card. They have some pritty good rebates at times.
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06 -
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 16:14 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
