  1. If you want to manipulate them and max out your DVD's main movie, use this thread at doom's forums and use this program....sweet little utility....
    http://forum.doom9.org/showthread.php?s=&postid=279067#post279067
    TeF
    Jul 2002
    Scotland
    Can you recommend how to use the utility ?
    dlb.
  3. yeah, just click "preferred settings"....pretty simple...or just read the doom forums on the sticky note for more details for tweaking.
  4. Downloaded and opened the program but can't see any buttons on the very bottom to click. At maximized, and can't read the text in the selectable buttons. Any one else have this problem? Can someone that can see them post which one of the three it is? I can just see the very top edge of 3 buttons. Thanks in advance
    Jul 2002
    Lancs, England
    I would guess your looking at your monitor in 600x800 if you go to 1024x768 you should now see the 3 buttons.......if still can't see
    1st is default 2nd is recommend 3rd save
  6. No, I'm already at 1024X768. Should I change it to something else then??? But, you telling me buttons will work..Thanks for the quick response.
    Jul 2002
    Lancs, England
    I really dont know why your unable to view the 3 buttons i have just downloaded it and it all shows up fine in the window perhaps someone else outthere may have an answer?
    just a thought but can you pull down your task bar or have you already done so?
    I also dont think you need to mess with the buttons anyway as you can change by moving the slide bars & if the want to save setting its 3rd button
  8. 1.0.1 is out....800x600 is ok now
