I have Google search this forum, but I'm not sure I have found what I need to know![]()
I have d/l, split and burned my AVI now its UPSIDE-DOWN![]()
I played it on the PC and its the right way up and plays fine, what have I done wrong ?? and how can I sort out the problem??
Thanx Dy![]()
My avi is downloaded, is that what u mean ? I dont know which codec is being used either cos i got so many
i just followed instructions to get codecs when i needed to, its a bit double-dutch to me
Dy :wave: -
go to the codecs setting an put then rigth
if you have installed the VOBSUB you have Direct VOBSUB Config (or something) open and adjust
or
when playing w/ zoomplayer rigth-click / filters and try one that could put your image in the place
that is simple
Vegas 8.0 - ITS UPSIDE DOWN!
By 1320Video in forum EditingReplies: 7Last Post: 17th May 2008, 13:35 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 08:13 -
My video is upside down
By Baldrick in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2007, 11:02 -
Build 2.5.3200 - Successful AVI-conversion - Upside down image..
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 4th Oct 2007, 17:58 -
Upside down movie after the filmMachine
By Belfour in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2007, 07:29
Any other suggestions ?? Anyone??
