Hi downloaded a video clip tried to burn it to disk with Nero Vision Express transcoded the first 7 minutes then i get a XP error message up so idecided to use Vdub getting simlar problem any ideas
thanks in advance![]()
First off , Nero stinks for encoding. Use TMPG or CCE for encoding. Then Nero for burning. You will have to play with them some and read around to get best results, but going to TMPG or CCE alone will be of great help to you.
Use Virtualdub to scan and remove any bad frames first!
Heres a guide: https://www.videohelp.com/forum/viewtopic.php?t=142555"Art is making something out of nothing and selling it." - Frank Zappa -
thanks but i have used TMPG Enc with simlar problem tha movie clips i downloaded were in two parts the second part encoded great but the first did not
once for you reply -
that wot makes this forum great the first class help thanks will try the guide
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 13:15 -
Problem with convertion to xvid...
By zovx in forum Video ConversionReplies: 11Last Post: 11th Feb 2010, 07:43 -
MKVTools and Xvid problem
By Geiger9 in forum MacReplies: 5Last Post: 18th Jun 2009, 16:34 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 12:25 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
