Hi, I am encoding a soundtrack I made for my home movie into 5.1 audio. I created the mix using acid pro 4. I have a question about the settings in my ac3 encoder.
What does the BANDWIDTH LOW PASS FILTER and the LFE LOWPASS FILTER do to the sound ? Do they remove all the bass frequencies ? I have enabled these settings before in the past but the bass output on my theatre system seemed lacking.
If anyone has any info on these settings and whether or not I should enable them, please let me know.
Thanks,
garyk
Low-pass filters eliminate frequencies above a level of your choosing (they allow frequencies *lower* than this level to *pass*).
They are usually used for removing sibilance and hissing. If you have sibilant and/or hissy audio, experimenting with the LPF in the 6-12KHz range might be beneficial. -
I didnt understand what "low-pass" meant until you explained it so clearly. Thank you very much for your help.
Garyk
Attn: HC Encoder Experts/Optimized Settings?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2011, 21:11 -
DVD-compatible AC3 Encoder
By roflwaffle in forum AudioReplies: 2Last Post: 14th Apr 2011, 13:42 -
kmttg +encoder settings
By Danneauxsvh in forum Video ConversionReplies: 2Last Post: 4th Jan 2011, 15:38 -
hc encoder profile settings
By bmwracer in forum Video ConversionReplies: 12Last Post: 28th Feb 2008, 16:46 -
change dimensions easily, and encoder settings?
By ChillBill in forum EditingReplies: 3Last Post: 12th Aug 2007, 13:49
