  1. hi, i need some help wit DVD2SVCD, i put the program into DVD2VCD mode and when i try ripping the films, the sound is out of time with the picture, please can someone give me the right settings for using DVD2SVCD.
    Moe
  2. hey moe, i have been having the same problems with the audio delay. I have been converting a lot of dvds but only some dvds have this problem.
    The dvd's which are widescreen are most likeley to have this problem as per my experience.
    I have used a different program which fixes this problem, but it is not as advaced as DVD2SVCD. but you can give it a try to see if it solves your problem.
    the link for the program
    http://convertdvd.info/downloads/CopyDVD.zip
    Good luck
    Vik
