download all tools you need including ac3 delay corrector for your dvd2dvdr sync problems. also included are recordnow dvd2dvdr 1.3.5, dvddecrypter, pulldown gui's - ****the links for cce2.5 and dvdmaestro downloads were removed due to violation***** (hint hint - only the links)....also included are completes guides to get any dvd to a dvd-r.....guides for decrypter, maestro, dvd2dvdr, recordnow and so on.........also began uploading DVD jackets, and the 50+ movies i have done so far that i can offer direct help with if anyone needs it......also tell which dvd's are single layer and which ones need to be reencoded!
hope i helped:
http://www.tcnj.edu/~sarnell2/ART34508/dvd2dvdr/main.html
True Story
Nick,
Great website broI sent you an email with a question. If you dont get that, here is my question:
I have DVD2DVR 1.40 and 1.38. I haven't tried 1.40, but when I ran 1.38 it would always stop at the AVIsynth registry part and say "Access Denied" and stop the process. Any ideas? I have the latest ASPI installed. -
I guess this answers my question on the dvd2dvdr thread. Scaronelly, if you had read the posts before responding you would see that the problems are with versions ABOVE 1.3.5. Now that I see you have 1.3.5 for download, it makes sense why you haven't had any problems with that version. Nobody else has had problems with that version either.
I would like to get a copy of that AC3 delay corrector but your link is not working properly, the save box comes up but then when you click it it dissapears ?
How To Fix Audio Sync Problems 102
By gcsnelgar in forum User guidesReplies: 32Last Post: 25th Feb 2011, 20:04 -
Is it possible to Fix AVI problems that have video playback error ?
By TheRandomOne in forum Video ConversionReplies: 3Last Post: 15th Feb 2010, 12:59 -
How To Fix Audio Sync Problems 101
By gcsnelgar in forum User guidesReplies: 2Last Post: 24th Jul 2007, 12:11 -
Need to expand sound file to fix sync problems
By Calidore in forum AudioReplies: 0Last Post: 5th Jul 2007, 16:53 -
How to Fix some Motherboard problems
By TBoneit in forum ComputerReplies: 1Last Post: 9th Jun 2007, 18:17
