I've got a movie (avi - divx) that I want to convert to mpeg but when I put it into virtualdub (to check the file) it tells me that there is an unknown audio codec on it.
So I can't convert it to mpeg (because it can't decode the audio).
Can somebody tell me how I can figure out what codec the audio whas encoded with?
I have got the Nimo Codec Pack installed!
Its Ac3, Dolby Digital Surround
Try to find an AC3 codec or just update your Direct Show -
Gspot, in the Tools section under Other Tools, will test any file and report the required codec and if it is installed.
"Art is making something out of nothing and selling it." - Frank Zappa -
G Spots the best, not only tells you what codecs, but also whether or not you have it installed. :P
gspot told me that I've got the ac3 codec installed but in virtualdub it still tells me that it is an unknown audio codec! -> it wont let me encode it to mpeg
download the latest verson of the codec, that always seems to work for me,
found another way to solve the problem myself!
I used Goldwave to make a .wav from that ac3 and then i made a new avi in Virtualdub. (Audio as a wav source -> convert it to mp3 and video as direct stream copy...)
...seems to work!
Thanks to Goldwave - a very helpful tool! -
I use Goldwave for AC3 and MP3-VBR sound. Vdub does not convert AC3 and you need Vdub-MP3 when you have MP3-VBR. Goldwave is definitely the easiest way but I think Soundforge and Besweet will do the same thing.
Unknown audio in AVI files
By courtneye in forum AudioReplies: 6Last Post: 29th Sep 2011, 10:24 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Audio Codec after Synchronization
By Aurlito in forum Software PlayingReplies: 0Last Post: 13th Mar 2010, 10:47 -
unknown codec, mov container
By jlz901 in forum Video ConversionReplies: 4Last Post: 1st Apr 2009, 19:25 -
need mpeg audio codec?
By tomm2000 in forum Video ConversionReplies: 7Last Post: 7th Sep 2007, 20:34
