I Wonder What codec you guys using After Capturing From TV. And Which one is best And Not Too Large in filesize.
Thanks From Now.
I like HuffyUV. The quality is great, and the file sizes are much better than capturing uncompressed.
Huffyuv will run 15-30 GB/hour. It's lossless (perfect). MJPEG will get you 5-20 GB/hour, is virtuosly lossless (it's 'good enough') and usually my choise for big captures. MJPEG has adjustable quality settings that affect CPU usage, quality, and file size.
Uncompressed video you probably can't capture because of the bitrates involved.To Be, Or, Not To Be, That, Is The Gazorgan Plan
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 21:26 -
Dv Codec
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th May 2008, 14:10
