  1. How do you make still menus with sound DVD Studio Pro? I findly started to make my owh dvd's but still menus with out sound are lame. Is there a way?
    Feb 2002
    Use a pict file for your menu. Then an option for audio will be there. If you use a photoshop file, there is no chance to select an audio assett.
    Feb 2003
    Bloomington-Normal
    You need to use Corel to generate a PICT file that ahs an embedded sound layer.
    I personally think that is stupid.
    Jul 2001
    usa
    you need a pict file, a flattened psd file might also work, then drag your audio in and set it to loop. layered psd files won't give the audio option.
    pants
    pants on, pants off, pants the floor.
