I captured a movie on Adobe Premiere 6.0. I then had it turned into an Mpeg file. The only problem with it is that its about 2 gigs.
Does anyone know of how to compress the mpeg to fit on a CD?
I tried using it in TMPGEnc the way it was, but that didn't work. I even tried going through DVD2AVI to get .d2v and .wav files first, but that didn't work either.
I am able to make it an avi file as well if that helps as all...
Thanks for the help.
If everything is infinite then nothing is definite.
When you say that it didn't work in tmpgenc do you mean that it gave you an error message when you tried to use the mpeg as your source? If so, then go to the options menu in the top left corner and select 'environmental settings', then click the first option under the 'general' tab which allows says something like "enable multiplex..." It should use your file now as both the audio and video source and should work. If you should have trouble with the audio portion, you can always convert that to a wave by opening the mpeg in Goldwave... Hope this helped and wasn't old info to you..
It accepts the mpeg as a video and audio source. But when I finally start the process, the source position remains at zero...
Problems with mpeg-2 ts
By SINZAR in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2012, 17:39 -
Mpeg Problems
By marbletravis in forum EditingReplies: 4Last Post: 23rd Jun 2008, 13:24 -
MPEG-2 Problems...
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 14:14 -
Mpeg Layer 3 problems
By ada1984 in forum EditingReplies: 7Last Post: 8th Nov 2007, 22:30 -
MPEG 2 problems
By specwarrior09 in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2007, 13:16
