  1. I have a film encoded in NTSC, it is 1 1/2 hours long.
    It came on VCD originally and any copies of this VCD work fine in standalone DVD players
    The problem starts if I put it on my computer as an .mpeg or even as a .dat, when I play it in any player the player insists that the film is 7 1/2 minutes long.
    I have tried to re-encode the file with Tmpgenc, Procoder & Cleaner. If they start at all they freak out around the seven minute mark.
    I have used MPEG Corrector and this seemed to have no effect.
    If anyone can enlighten me, please do, I'm buggered if I can fugure it out.
    If I don't encode this to PAL I am in danger of being knocked off by my mates. Help, the situation is desperate.
    Mar 2002
    United States of America
    Have you tried de-multiplexing and then re-multiplexing???
    Mar 2002
    Demultiplex:
    Is when you split the video and audio to separate files.
    Multiplex:
    Is when you join the video and audio to one single file.
    Hope That Helps!!! :P
  4. Hi,
    Yes I have tried with Tmpgenc with both simple and normal de-multiplex and it freaks at the same point about seven and one half minutes into the movie.
    I'm stuck for ideas.
