hi guys and girlies
ive got this dvd movie, which i can play on my dvd player connected to my tv but it wont play on my computer - dvdrom
im using windows media player and just installed windvd but neither seems to work.
when i go into MY COMPUTER and look at the at the DVD drive, the movie doesnt even display.
Should i install another dvd player on my computer or update my codecs
im using windows XP
Thanks if anybody can help
hi.. uhmm.. what kind of dvd player do you have on ur pc? and it has nothing to do with your codecs anyway cuase a dvd player and a programme for it should do the trick on their own
try downloading 'power dvd' and open your dvd. if that doesn't work either maybe ur pc dvd isn't region free and u bought a diff region movie. and be sure the dvd is installed correctly, maybe that's the bad guy....
ciao
If a DVD/CD will only play on the computer...
By LellyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2010, 08:38 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 03:49 -
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 18:41 -
dubbed DVD+R won't play on my computer
By TraceyG58 in forum Authoring (DVD)Replies: 3Last Post: 17th Feb 2009, 16:51 -
Play Unfinalized DVD on Computer?
By p_l in forum Software PlayingReplies: 3Last Post: 11th Apr 2008, 20:04
