Do I have select each item I want ripped and run the program until I get it all? The doesn't seem to be a check box for "select all".
are you trying to rip in file mode or iso cause if your ripping in file mode click edit then select all then rip
if it's a dvd9 you have to rip it in file mode and use another program to put it on one disc or dvdx copy to split it on two. If it's a dvd 5 you can rip the iso to your hard drive and then just burn the iso on one disc. Really depends on what your trying to do.
Hey thanks I got it to work. The DVD had a bad read on one file both in SmartRipper and DVD Decrypter so I finally just copied that file to my hard drive then it would rip with either program.
Rip DVD with scratch on it with DVD-Decrypter
By aslan in forum Newbie / General discussionsReplies: 17Last Post: 24th Mar 2013, 18:34 -
Rip DVD DVD Decrypter Issue
By kerb in forum DVD RippingReplies: 3Last Post: 20th Nov 2011, 19:42 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
DVD Decrypter crashing on rip error.
By mattstan in forum DVD RippingReplies: 6Last Post: 29th Oct 2008, 17:33 -
I can't rip with DVD Shrink or DVD Decrypter
By Baldrick in forum DVD RippingReplies: 77Last Post: 10th Feb 2008, 12:46
