Got a split avi im trying to convert to mpeg1, with the source avi ive ripped the audio and converted it to a wav format using vdub, also using vdub ive made a file with just the visual to minimise any errors.
With the visual and the wav file I use tmpeng to create the mpeg1, which plays ok until 20 mins through then it goes out of synch!![]()
I never had synch issues in the past, -I used to choose create pal vcd even though the avi was ntsc (didnt know not to then), and the only problem I had was jerky playback.
Anyone else have this problem? Its a OpenDML AVI DivX 3 Low-Motion avi, and its really, really, pissing me off!
Regards
Nish 8)
Did you scan the video stream for errors before doing anything else?
"Art is making something out of nothing and selling it." - Frank Zappa -
If your file has bad frames, here's a guide for taking them out:
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
DV AVI to AVI to DVD = Audio Error!
By video_noob in forum Video ConversionReplies: 0Last Post: 9th Aug 2010, 20:15 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
trying to convert AVI to DVD. mplex error. Cannot find .mpa file?
By anarchyx34 in forum ffmpegX general discussionReplies: 8Last Post: 14th Sep 2008, 20:14 -
Video error when playing .avi file - what to do?
By HenryDaniels in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2007, 22:00
