very wierd audio
i just made a vcd of an xvid(gangs of new york)
and now the audio is all messed
how do i corect it
thanx
Jordan Ennis
You'll have to be more specific. What programs did you use? What procedure did you use? What does "all messed up" mean?
"Art is making something out of nothing and selling it." - Frank Zappa -
ok
i used TMPGEnc
and i made a ntscfilm non standard vcd/xvcd with a bitrate of 1210 and audio bitrate of 160 and at 44100
and i framserverd the vieo from vdub
the movie is gangs of new york and the audio is like not in synch at all with the video
thanxJordan Ennis -
Okay. Did you scan for bad frames first using Virtualdub?
no
i never do
and the one time i did there was tons of bad frames but no messed up synch audioJordan Ennis -
Yes, sometimes the source has so many bad frames that removing them will wreck it. Unfortunately, leaving them in results in all kinds of problems. The encoder can crash or freeze and/or the resulting mpeg can have the A/V out of sync. Bottom line: Scan and remove the bad frames if you want good results, it's the most likely cause of your problems.
Hope that helps.
Here's a guide for removing those bad frames after you scan with VirtualDub:
https://www.videohelp.com/forum/userguides/142555.php
Hope That Helps!!!
:P
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Weird Mouse?
By fairytale00 in forum ComputerReplies: 1Last Post: 7th Jun 2010, 02:07 -
Weird Folder
By mn072065 in forum ComputerReplies: 7Last Post: 28th May 2008, 10:34 -
Weird Audio
By Thr0ttleman in forum Video Streaming DownloadingReplies: 8Last Post: 4th Apr 2008, 05:57 -
colours are weird?
By bennyboyt in forum Newbie / General discussionsReplies: 5Last Post: 23rd Dec 2007, 19:47
