is ther any programm that would let us play movies on my ps2 ie instant copy when i reencode will it play on ps2 or can i get movies from somewere that will fly write and work![]()
I just made 2 backups using
DVD DECRYPTER
DVD2ONE
RECORDNOW MAX
And they both play on my ps2 without any modchip or bootdisc ..They are in full colour also
the 2 films were tombraider and bourne identity
i have a full scart but my brother tried it on his and it works with the normal scart that came with the ps2
dont know if it works with every movie as i have only backed up 2
maybe someone else will help by telling us if this is the case with all movies done this way or any way for that matter
hope this helps -
Same here but i use IC7 instead DVD2One, work great with PS2 without mod chip or boot disk. Also it work when i burn image DVD with DVD Decrypter. I'm using Ritex DVD-R
=-VNPN=- -
What version PS2 do you have? I had some backups burned with Nero that worked a few times but do not work any more. I have the very first US version, which I think may contribute to the compatability issue.
I am in uk (pal) and have a version 7 ps2 ones i do as above all work but i got some from my brother a few months ago that only play in black and white because of them being( ntsa) usa not sure if the letters in brackets are the right way round but you will know what i mean
I have been wondering about this also.
I have "backed up" a few DVD's and they will not play on my PS2 but they will play on a friend of mines.
I have also authored original made DVD's and they will not play on my PS2 either but they will play on his.
Both my backed up and original productions will play on my stand alone pioneer DVD player.
He does not have a mod chip and I can't figure out why they will play on his but not mine. Mine plays normal DVD's just fine.
I just figure it has something to do with the date of release of the PS2 and the software abilities at that time.
Encoding for Playstation 3
By nerfgun in forum ffmpegX general discussionReplies: 52Last Post: 15th Mar 2010, 17:57 -
PlayStation 3 vs Philip 5990/37
By reg505 in forum Newbie / General discussionsReplies: 5Last Post: 18th Dec 2009, 10:36 -
Playstation 3 troubled? - Thanks Mr. Sony!
By videobread in forum Newbie / General discussionsReplies: 5Last Post: 22nd Dec 2008, 13:42 -
UK Playstation 3 Question
By Anakin in forum DVD RippingReplies: 10Last Post: 30th Aug 2008, 03:43 -
Playstation 3
By Jake802 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Jun 2007, 22:57
