hi
this is my system :
Toshiba 50" Projection TV - Hyper Pro 100
Pioneer DV-636D DVD-PLayer
Kenwwod VR-309 DTS amp 100wx5
BOSE 5 Speaker
Jamo Subwoofer 200W
and i want to change my DVD player cause i notes that Sony have better picture than my Pioneer !!
and also i want some extra futures .
i want a DVD can do this :
DVD-R
DVD-RW
DVD+R
DVD+RW
DVD-A
SACD
CD-R
CD-RW
VCD
SVCD = not importent
MP3
Progressive Scan
play PAL and NTSC
work with 110~220AC
have more than 500 Lines to give me good quality picture
DD , DTS , DTS/ES
play cheap media
i think thats all i need.. am i ??
i have only 300-350$.
thanks..........
http://www.mindlogic.com/MSDVD_PNSC_dvd-rp82_DTL.shtml
ok i can't see if the the RP82 can play SACD ??
and can this work with 110v and 220v ??
how is the picture and sound quality in this player ??
is there any thing you dislike in this player ??
thank you for reply ........
Go to www.area450.com and look at the Sampo range. These things are top quality without the price.
Paul -
thats the wrong picture in that ad.
here is what is really looks like
http://www.prodcat.panasonic.com/shop/NewDesign/ModelTemplate.asp?ModelId=16348&show_a...ategoryId=2977
plays dvd audio -- well you can read all the other specs on the panasonic web site ..
also it has superb reviews on any of the user review sites ..
panasonic claims it does not play SVCD - it even says this in the manual , but it plays them fine for the most part - in fact it even says SVCD on the screen when you put one in ..
I does have a problem with SOME svcd's .. seems to not like data burned right to the edge .. on some brands of disks ... copy same stuff over to another disk and its ok .. not a big problem ...
it says on it 100-220v but you should always get that confirmed.. -
thank you very much guys.
just want to know if the RP82 play Super Audio CD or NO ??
or you mean every DVDplayer can play DVD-A will play SACD ?? -
Currently, ONLY Sony, Philips, Marantz, Accuphase, Denon, Kenwood, Aiwa, and Sharp are manufacturing SACD players
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
burning 300 mpg video files on DVD?
By twister6 in forum Authoring (DVD)Replies: 3Last Post: 2nd Nov 2008, 20:02 -
rca dvd rtd 300
By nickoleyt in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Oct 2008, 00:59 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 09:28 -
Why does the movie 300 cost $5 more on HD-DVD than Bluray?
By louv68 in forum Latest Video NewsReplies: 10Last Post: 5th Aug 2007, 22:09
