Main Concept encodes my SVCDs about twice as fast as TMPGenc does...it does not however keep the proper aspect ratio.![]()
I can get around this by frameserving from Virtualdub, using the resize filter to add the necessary borders...but this makes Main Concept run about half the speed as it does without frameserving....which means it is about the same speed as TMPGenc...which defeats the object cos the reason I want to use Main Concept is because of its speed!
So to get a proper aspect ratio SVCD I can either use TMPGenc alone, or Main Concept frameserved from Virtualdub...they both take the same time.
I have a feeling the slowdown is the fault of Virtualdub and not Main Concept....if this is the case is there another program which will frameserve the video to Main Concept faster?...I have looked at AVIsynth (for about 10 seconds before I realised it looked HIDEOUSLY complicated).
You can try a couple of things. You can edit the header (already discussed in several other threads) to make sure to make sure the settings are correct for the aspect ratio.
Alternatively, you could ask at the MainConcept website if there isn't someting you can set. There are a lot of settings within MainConcept that I haven't dug all the way through yet. There is probably something you need to adjust that is in the advanced panel.
Alternatively, frameserve and resize using avisynth which is much faster than VDub. Again the how to is already discussed in several threads here. I've had good luck using avisynth to MainConcept for CVDs so I presume that it would work fine for SVCDs -
Thanks Sammie...I'll check out the Main Concept site...if no joy there I might try AVIsynth again
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 20:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 7th Aug 2010, 00:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 17:19 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 16:22
