I searched the forum and wasn't able to find the answer to this question. After using Disco+ or DVDBackup or any other software and you're left with a Video_TS and Audio_TS folder, what do you drag to toast to make a useable dvd? I've wasted several blank dvd-r discs by doing this wrong and just want to know what it is exactly that you have to do. Thanks.
There two ways,
In Toast, Option Click the button 'Other', select DVD.
1) On your HD, make a new folder, change the name to what you want, place the AUDIO_TS and VIDEO_TS folders inside, then drag the folder to the Toast window 'DVD'.
OR
2) In Toast Click 'New DVD', a folder will be created named 'Untitled DVD', change the name to what you want (Usually the same name as the original disk), drag the AUDIO_TS and VIDEO_TS folders inside.
If you want to test it before burning, you can save it as Disk Image. When it's finished, mount the image, DVD player should start and you can check everything out. Have fun.
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 17:41 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 12:23
