sasi,
decided to take your advice and try mainconcept encoder but i'm used to ripping then using dvd2avi to make my d2v file but mainconcept won't except it.........what am i doing wrong
-just drop the vobs into mainconcept .. ac3 files and all if you want ..
-dont bump your post
-be more specific on yoru problem ..
- thank you -
if you DO want to use dvd2avi ... convert the d2v file with vfapi to a fake avi file ..
thank you bj, i'll give it a try, sorry for bumping i was getting desperate
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:27 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
