Hey everyone....... I am needing some help in view a movie file.... Initially I had a friend send me a movie file in a TAR format and I burned it to disk via a CD-R and can not get it to view through any means (both via my computer or stand alone DVD player's), so I could use some help. Please be gentle and nice for I am new to this type of stuff. Below I listed out the directories that are on the questionable disk, also I listed the sub-files below each:
-EXT
scandata.dat
-Mpeg2
Avseq01.mpg
Avseq02.mpg
-Segment
-Svcd
Entries.svd
Lot.svd
Info.svd
Psd.svd
Search.dat
Tracks.svd
My question is does this have to be burned via a DVD writer???? If not, how do I go about viewing it on a stand-alone dvd player???? What or how can I view it on my computer, meaning will it play via a certain viewer or version of viewer????
Thanks for your help...........
VCD and SVCD are burned on CD's, don't need a DVD burner. Will your standalone play SVCD? You need to look that up. To play on computer you will need an MPEG 2 decoder. You can use WinDVD or PowerDVD to play the MPEG 2 Files. The files are in the Mpeg2 dir, Avseq01.mpg and Avseg02.mpg these are the files you need to play.
Not all stanalones will play SVCD. Like I said you will need to look up your player to see if it will play SVCD's. Look to your left under DVD Players.May the force be with you.
DVD for viewing on tv?
By frenchman96 in forum Video ConversionReplies: 1Last Post: 15th Jan 2010, 12:09 -
viewing hf200 on tv
By jim_joh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Oct 2009, 20:20 -
Recording and viewing problem
By snigelb in forum ComputerReplies: 1Last Post: 2nd Apr 2008, 09:21 -
Help Viewing Videos
By Demonolith in forum Newbie / General discussionsReplies: 2Last Post: 11th Jul 2007, 12:03 -
Converting For Better Viewing
By The Sumerian in forum Video ConversionReplies: 1Last Post: 16th May 2007, 11:06
