I took the AVI and WAV file. Loaded into TMPEnc. Now I have a MPG. Thats worked great, Except the sounds don't jive with the movie.LOL. What do I need to do to correct this problem?
Video Info:
Media length: 115min 17.76sec
Video Format: 704x400, 24bit, 165844 frames,23.976 frames
139kb/sec, Divx codex
Audio Info:
Media length: 114min 20.960sec
Audio Fromat: PCM,48,000hz 16bit Stereo
Thanks,
Your audio is almost a minute shorter than your video! First, did you scan for, and remove any bad frames from your source? Does it start out in sync then get gradually worse? If the answer is yes to both, then your wave file can be stretched to match the video. I use Goldwave which has a "Time Warp" function under Effects. Good Luck!Originally Posted by tands"Art is making something out of nothing and selling it." - Frank Zappa
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
