  1. Ok here's what I did, I copied the whole DVD unto a DVD+RW using DVD Decrypter, but what I'd like to know is, can I somehow turn my DVD+RW disc into non erasable, so noone will erase it either by mistake or on purpose.
    Thanks in advance.
  2. Yea - write it onto a DVD+R!
    But seriously, DVD+RW was meant to be erased. When you use something like Nero to erase it, Nero doesn't care what you did with it - it will erase the DVD+RW. Not even "Fixating" it will work.
    I have tried the same thing, and no results.
  3. jurynel asked
    How to make a DVD+RW unerasable?
    Answer, in the same way that you make a CDRW unerasable
  4. Originally Posted by bugster
    And how is that?
    I mean I'm pretty sure how, using Nero with a CDRW but how do you do it with a DVD+RW?
  5. And how is that?
    lol..you got a lot of reading to do if you are serious, which it appears you are. The same way you make a CDRW erasable is YOU DON'T! Well, maybe if you erase the DVD-RW 1,000 TIMES OR MORE, it may screw it up to where you can't erase it anymore. Give it a shot and let us know how it works.
  6. Member rhegedus's Avatar
    on the jazz
    Like the man says........just burn it to DVD+R. Surely you've got one spare?
    Regards,
    Rob
