[size=18]hello..i downloaded an mpeg file 800+mb's in size and it works perfectly well on my pc..
i split it using tmpgenc,so i could view it on my regular dvd,however,the second disc has no sound..
the first disc is perfect so i'm really at a loss as there is no reason i can think of that would explaine the absence of sound on the second disc..the video and audio streams are exactly the same..
.i would appreciate some advice from anyone who has an explaination..
thank you,
bigwardo[/size]
keep safe/happy........a day without a smile is a day lost:-))
did you split your file before you encoded (source range) of after (creating to mpg files)
If you did it the first way, this may be your problem: When encoding the first file you may have chosen a smaller audio bitrate when using TMPenq, but a larger one when you did your second file.
This is aproblem I have with my Phillips DVD player so to over come it you simply must encode with a smaller audio rate.
If its the second, I'm afraid I dont have a clue!!
Yeah Baby!
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
sound choppy on rmvb file in my DVD disc.
By csh in forum Software PlayingReplies: 4Last Post: 31st Oct 2008, 22:13 -
Burned dvd video disc has no sound
By funnybunny in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2008, 16:00 -
Disc copy of a dual layer disc
By kingjames in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2007, 14:52
[/size]
