How much internal memory should one look for when doing encoding jobs using TMPGenc ? Would more mean faster ? How long does it take to encode a 750 mb avi file to mpg2 svcd format approx. ?
Thank you.
Originally Posted by marcelr
What is your source, how long is the movie, how fast is your cpu? All these (and more) have a big impact on encoding time. -
Conversion is CPU intensive and doesn't rely on memory for speed. Within limits, and depending on what the computer is doing at the same time (surfing etc.), changing the amount of ram won't speed up conversion times. As bugster said, 512 MB sems to be the optimum amount of ram beyond which, in windows anyway, things won't speed up much.
Some people report conversion times of about 1.5 hours for a 2 hour movie on the low end. On the high end, the skies the limit. If you want an estimate of conversion time you'd have to answer these questions: CPU type and speed? Conversion program? Video length (not size)? CBR or VBR? Any filtering? With my setup I can do a 2 hour movie conversion (CBR, no filters, TMPGEnc) in about 3 hours. Your results may vary."Art is making something out of nothing and selling it." - Frank Zappa -
When I upgraded from 256 MB of 133 SDRAM to 512 MB DDR 266 I gained Nothing in encoding speed.
I gained in games, and certain applications that can use a lot of cache. But generally speaking encoding is a CPU thing (that's why celerons can encode so well). The other difference (primarily between Athlon's, PIII's, and PIV's) is the SSE, SSE2, MMX, MMX2 instruction sets (Athlons don't do MMX2 and P's don't do SSE's ?) that make a slight difference to the CPU speed rule.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
dvd recorder internal memory
By mgy999a in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Sep 2009, 12:47 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 17:12
