Captured a mpeg 2 file. Was to big ,5 gig. Stripped the sound and video. Re-encoded the video. That's ok but I need to change the mp2 file to ace so it is readable by spruce up... or does Ulead know the difference?
Don't give in to DVD2ONE, that leads to the dark side.
Spruce up will quite happily handle mp2 audio. Howver you must either multiplex it with the video before importing into spruce, or you must use a .mpa file extension.
If you really must convert to .ac3, then use HeadAc3he, available in the tools section.
Hope this helps. -
I assume both give the same results. Which is faster?
Also, the multiplex I can do in Tmpgnc... right. What about the MPA? How do I do that?Don't give in to DVD2ONE, that leads to the dark side. -
Originally Posted by Marco33
Multiplex in Tmpgenc, correct.
Faster, well using a .mpa file extension means you don't have to bother with the multiplexing step so if you already have seperate audio and video streams, stick with that.
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
