Yeah, virtualDub seems to create audio sync issues when opening certain mpeg files.
The raw mpegs themselves do NOT have any issues with audio sync, but I noticed that once I opened the files using vDub(mpeg2 compatible), then problems would arise with the audio no longer in sync with the video.
Anyone know why this happens?
I'm guessing something goes wrong in the "parsing interleaved video" process that occurs right when you choose to open the mpeg in vDub.
I find this strange because it only seems to happen on certain files.
By the way, I'm encoding the mpeg into divx, but that should NOT be the problem because I check for the sync issues using the preview provided by the input file (not the output file that is the result of compression).
What's going on here?
Is there anyway I can get around this problem?
Results 1 to 1 of 1
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
vdub avi file opening problem
By naveenkrish in forum EditingReplies: 3Last Post: 8th Jun 2010, 11:54 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35
