  1. hi all, im using dvd2svcd w/ tmpg for my creations..and nero to burn... ok heres my ?. once I've copied my movie I remove movie files from my comp. Using the default setting of latest dvd2svcd the files go to the Movie folder of program.
    Is it safe to delete everything in that folder? I failed to look before ripping so dont know if it was empty before or not. but after conversion there are tons of files, using tons of space.
    he who stands on toilet, is high on pot
    Feb 2003
    England
    once your movie is safely burnt i see no reason why you should want to keep your files, infact you need that folder clear if you use it for your next project.
    if im using tmpg (very rare , im a mainconcept convert) i tend to hang on to my vobs, my.2ds and my encoded audio just incase i want to re-encode
    with a differant template ect, i just put them in another folder.
  3. thx. i figured the should be emptied, just wanted to be sure.
