  1. just bought it and it wont run properly on my pc . i meet all specs required and more but is still to choppy to play. tried all the latest drivers as they suggest and more memory,but still not running right,all other command and conquer games run ok. fed up game cost me a lot of money. [/img]
  2. Member rhegedus's Avatar
    on the jazz
    You mean C&C Generals? This isn't a games forum.......
    However, having spent a week finishing it, I can tell you that it is very PC hungry. My P4 2.26/1GbDDR/64MBvga was slowing down on some of the more complex screens with lots of movement. So it doesn't surprise me that your PC would get sluggish.
    I sometimes think that the minimum specs are needed just to load the game!
    Regards,
    Rob
    Nov 2002
    netherlands
    Generals sucks dude.. the missions are just to simple and i think not every body who bought the last c&c's have generals cause of the damn high pc requirements oh and yeah why go here with your game question ? go to gamespy forum or something! sorry im a little ^#$%^#$&
    ciao
  4. i cant see the link between vcds and C & C generals but i know the answer n e way m8. Basically C & C generals, although being porcessor hungry, is also highly dependent on graphics cards. so, if you are runniung less than a 1.4 Gig T-bird (or 1.4 gig P4) and less than a Ge-Force 2 Ultra (or radeon 7500) then you may struggle! 512 megs of ram is handy too! I have looked at your pc spec and your cpu is more than fast enough, however, the chances are you have a Ge-Force mx graphics card which is probably your problem m8! there isn;t much you can do about that!
    1)Why Not Overclock a little?! speed 4 free!!!!
    2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website
