The trials of being a newbie are really starting to take their toll!!![]()
I am trying to convert SVCD to DVD and I have encountered a number of problems with the tools that I am using to do it.
Firstly, I tried converting the MPEG2 files on Ulead DVD Movie Factory, but this kept the aspect of the film the same, i.e. letterbox and I need it to be full screen. Other than that and the time it takes, everything else was perfect.
After looking on the forum, I decided to use DVD2AVI & TMPGEnc, but while I have the picture size I want, the sound cuts out after 10 minutes or so.
So, is there a way to change the aspect of the picture on DVD Movie Factory or can you advise what I should be doing with TMPGEnc. Of course, if there is an all singing & dancing tool I could be using, let me know!
Thanx
Results 1 to 1 of 1
Just a tall man trying to make his way in the small world.
How to delete a menu & create/insert a new one with Nero Vision Xtra?
By snowseals in forum Authoring (DVD)Replies: 22Last Post: 27th Aug 2011, 00:03 -
No audio sound on DVDs using Nero Vision 5.3.3.0
By dweis in forum Authoring (DVD)Replies: 9Last Post: 25th Jun 2008, 19:06 -
Help with popping & cracking sound from pc
By gyles in forum AudioReplies: 1Last Post: 12th Aug 2007, 14:54 -
Sound & Vision Home Theatre TuneUp
By rico1 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2007, 14:03
