Just bought a Canon ZR70 and a Sony DRU-500AX setup last night .
I used the trial version of Ulead Movie Factory and made a five minute
DVD onto a Memorex DVD-RW and it works good in my Mintek 2110 at
a quality setting of 7. I then set the quality to 15 and it was somewhat
jerky. Can anyone tell me if I need more cpu, ram or what??
Also, is DVD Movie Factory the best software for this?? Freeware would
be preferred. I posted this before and was told to use DVIO. I tried it but it had no audio. Is this normal. Am I doing something wrong with DVIO, is Ulead Movie Factory ok but I need something for my pc to capture in the absolute best quality??
Apparently ya'll don't like my question since noone will answer..
Thanks!
Kevin
you dont capture minidv .. its just a data transfer over your firewire ...
i dont know much about ulead to answer your other question ..
capturing minidv tapes
By zoranb in forum MacReplies: 62Last Post: 9th Feb 2014, 06:07 -
Minimum System Requirements for capturing miniDV
By darkwhite in forum ComputerReplies: 19Last Post: 27th May 2012, 08:21 -
Capturing Old MiniDV with Canon HV30
By assman24 in forum Capturing and VCRReplies: 8Last Post: 14th Aug 2008, 02:41 -
Automated MiniDV Capturing
By euphoricdream in forum MacReplies: 0Last Post: 10th Mar 2008, 11:05 -
MiniDV to DVD - Questions about quality (SP vs. HQ)
By nikbone in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 16:57
