  1. I have cce 2.5 sp and panasonic plugin 2.51 and i want to install it on flask, how do i do that?
    Feb 2001
    Berlin, Germany
    Have you installed FlasKMPEG? Then read the docs please.
  3. How do you install the cce 2.5 sp, it says you need adobe premiere 5? I have installed the panasonic plugin but the cce won't install. I have the patch and crack but it won't work? Help!!!!!!!
    May 2001
    chicago
    you need this program called.....regdrop I believe
    it's just a simple .reg file that tricks CCE or another plug-in into thinking that you have premiere installed, thereby allowing you to install the appropriate plug-in
  5. Member Dougmeister's Avatar
    Sep 2001
    I installed FlaskMPEG, then the Panasonic Premiere plugin, but it does not show up in the output formats. I installed Adobe Premiere, then re-installed the plugin - still didn't show up in Flask. Are you saying that I need to register one of the files from the plugin even though I have Premiere installed?
    Feb 2001
    Berlin, Germany
    copy the plugin to the flask directory and rename it.
  7. Member Dougmeister's Avatar
    Sep 2001
    Thanks, Truman. But rename it to what?
    Feb 2001
    Berlin, Germany
    usually *.prm to *.cm.flask
    <font size=-1>[ This Message was edited by: Truman on 2001-09-28 09:47:29 ]</font>
