Not sure if this is the correct forum for this question, but it seemed to be the most likely.....
What I'm trying to do is merge the individual RF, LF, RR, LR, C and sub wave caps and reconstruct an AC3 file. As I have not been able to sucessfully capture the AC3 directly from my Laserdisc player/RF demodulator, I decided to perform an analog cap of the individual channels coming out of my reciever/decoder. I'm now stuck on how to merge these WAVs into a DDWAV or AC3 to burn to DVD.
Any thoughts?
TIA
Ted
Well if sonic foundry still makes soft encode, that would be your best bet, although I hear its rather pricey. I think there are other programs that might handle 5.1, but you should try to search the forums for dolby digital or ac3 to look up old threads on this subject. Then there's always google...
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 08:00 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44
