  1. I've tried succefully packed special features with the main movie and using DVD2ONE to compress and fit on one disc. This is simple:
    After you ripped all the files to a VIDEO_TS folder and viewed the vob files to determine what you want to keep, simply delete all the rest files including all BUP and IFO files. If your main movie does not start with VTS_01_0.VOB then renumber it to 01 and simply renumber the extras follow the last movie file number.
    Next, launch Ifoedit and click on "create IFOs" and bring in the first VOB file and save it to a VIDEO_TS folder (you can check same as source). Now you have a complete and ready VIDEO_TS folder to be burnt. If it's over 4.3GB then just use DVD2ONE to compress it to 4.3GB.
    This method does not allow you to have menu, it simply takes the extras and make them becomes chapters, so you still can use chapter selection and fast forward. But at least it keeps what you want with the movie on one disc, and it's easy. This method will also allows you to creat your own DVD with different VOB files, simply renumber them in order and use Ifoedit to get new IFOs.
  2. Great idea there since DVD2one is so fast. Is IFOedit easy to use?
  3. As fast as DVD2ONE (in terms of getting IFOs I should say).
