i have two files that i extracted that are about 813 mb apiece. unfortunately my cdr disc is 700m. i tried overburning using vcd easy but not only did the last 10% get cut out the audio was out of sync on the last 15% of the disc. any suggestions on how i might fit them onto my 700mb and would there be a lost of quality. would the best thing be to buy 800mb discs.
For information on CD capacity check this: https://www.videohelp.com/forum/userguides/135642.php
A standard 80 minute CD will hold 700MB in regular data mode or 800MB in Video CD mode. You are overburning to get 813MB, but not too much. You need both a CD burner that will allow overburning and a DVD player that will play it, otherwise you can get the problem you describe. There are 900MB CD's and you may want to try them but the same rule applies, your burner and player might not be compatible.
The files can be re-encoded at a lower bitrate to make them smaller. The lower bitrate will not affect quality much, but there is always a loss when a clip is re-encoded.
Suggestion: What about joining them, then splitting into 3 files? No re-encoding, no loss of quality."Art is making something out of nothing and selling it." - Frank Zappa -
i tried using tmpgnec as decribed here and the audio was out of sync and the picture was a bit jerky. help. this was when i decided to cut my two files into four. when i tried joining my two files for the purpose of cutting them into 3, the resulting large file froze on the first frame. i hope someone can help me.
I need some sound bytes if that is possible.
By ingeborgdot in forum AudioReplies: 4Last Post: 25th Apr 2012, 21:53 -
Need number of bytes played per millisecond
By rpolavar in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 01:41 -
ffmpegX - flv to mp3 - no bytes
By Noodles4 in forum ffmpegX general discussionReplies: 6Last Post: 5th Aug 2010, 20:45 -
says it succeeded but file is 0 bytes in size
By mlevin77 in forum ffmpegX general discussionReplies: 6Last Post: 21st Oct 2008, 18:04 -
Bytes of a movie
By Jomapil in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2008, 10:58
