I have a freind who owns a Pioneer 333. He burned some VCDs with his Mac using Toast. They play the video fine but no sound. They play fine on his Mac. I burned him an XSVCD and mailed it to him. Playes the video find but no sound. I played the XSVCD on my Apex 600 before sending to him and it was fine. It also plays fine on his Mac and on my PC. Any ideas? His 333 plays DVDs just fine with both video and sound.
Is your player properly connected?
Do you have the correct audio settings in the player's setup?
MrSnakeSony DRU-500A v1.0d
Toshiba SD-M1302 v1006
Philips DVDR885P v1.7/8 -
Yes. I asked him if it played DVDs ok and he said yes with sound. So the problem is only associated with trying to play VCDs or SVCDs. They play with video and no sound. The one I made for him played fine on my Apex 600 with both video and sound.
Ok, mystery solved. My friend tried playing a DVD after claiming that it worked and found to his great surprise that it no longer plays sound with DVDs either. So the problem is with his player.
..........and the latest. The problem actually turned out to be his connection to his TV but now when the XSVCD and the VCD he made play the audio sounds as though the people inhaled hellium, his description, and DVDs play just fine. Again, the XSVCD I made from him with all the standard audio settings in TMPGenc sounded just perfect on my Apex.
Any thoughts or suggestions on this problem?
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
Pioneer DV-360, help with a "tinnitus sound"
By rimbaud in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Apr 2009, 17:01 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Compaq PC133U-333-542-A 256MB, SYNCH, 133MHZ, CL3?
By rkr1958 in forum ComputerReplies: 3Last Post: 21st Oct 2007, 19:54
