Hi guys,
I have got MMC 8.1, and the others components to install it in my system... but I heard another site that I should install also the catalyst drivers to work!! but this driver is only for RADEON family, which AIW 128 Pro isnt...
Can anyone tell me if I really can use MMC 8.1, with ATICDwiz.exe and DAO/MDAC components with my video card?
Fredİ
AFAIK MMC8.1 is for Radeon cards but there will be another version releasing later for legacy cards.I'm using MMC 7.7.1 and I'm not going to upgrade(if it ain't broke don't fix it).Check here for updates:
www.ati.com/support/driver.html
RE:CAT 3.2 drivers
I wouldn't install unless you are using a Radeon 7000 or higher. -
I have the AIW 64mb card from a few years back and you can use MMC 8.1 with no problems. I haven't upgraded to the new catalyst drivers yet. So far the new MMC is rock solid on my PC, and no sync problems.
Originally Posted by Bodyslide
Can you play DVD and capture ok? Have you installed the ATICDwiz.exe file (for dvd)?
i use MMC 7.1 and the original drivers ( 4.7078 I guess) ...
thanks,
fredİ -
the answer to your ? is cat 3.2 needed for mmc 8.1 to run. the answer is no.. i didnt upgrade my drivers until later and it worked fine.. BUT i have older cat drivers loaded.. Im sure you need some version of them for it to work.. i know you need DX9 and a few other new drivers and packs for it to work.. I have the 8500 AIW that is compat with these drivers.. i also have an old aiw 128 that is not compat with the cat drivers so the best i could do with that was mmc 7.5.
I have XP Home, I don't use the MMC for DVD. But so far I captured a three movie in dvd quality with no frames dropped.
thank you to all that answered...
I will give a try in MMC 8.1 (after a system backup first)
Fredİ
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 09:13 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
