  1. Hi,
    If the vob's for the movie only are < 4.7G how to do to rip them (with Nero) without having to use DVD2ONE with IC ?
    Thanks !
    You rip commercial dvds(encrypted dvs) with a ripper and not nero.
    https://www.videohelp.com/forum/userguides/141024.php#dvd5
  3. Sorry for not being too clear, I mean I'm just ripping the main movie from a DVD9 dvd, it just happens that sometimes the total size of the main movie vobs is < 4.7GB. How do I rip the movie only now ?
    Sade
  4. If I understand you correctly, you have a dvd9 where the MOVIE is less than 4.7g. If this is the case, you should be able to rip only the vob files using Smartripper and drop them into IFOEDIT and it will make new ifo's for you...that should be it.
